rwthomas1
Hello all,
Well, it's that time of the year for new sneakers on the 1100. When I removed the rear wheel I was greeted with nothing but dry dust from the drive splines. Hmmm, it's only been @10K, shouldn't be bone dry. Used new o-rings and the preferred Loctite 8012 paste. Looked like metal flakes too. Unfortunately there is more wear to the drive splines than last time as well.
After cleaning up the high points and deburring the wheel flange, I moved to the drive side on the swingarm. While scraping out all the buildup, I realized that the area inside of the splined, deep inside was packed with old, very hard paste. Since this is only my third set of tires on this bike I can only assume that this is residual from over the life of the machine. I never noticed before because I just cleaned the spline area and moved on. But there was at least an 1/8"+ packed in there. I dug it all out and cleaned it out with carb cleaner.
So now I have some shouldering on the drive side and more on the wheel flange. Probably hard to tell in the pic but maybe 10-15% of the total tooth width on the wheel flange splines. Now that everything is clean, when I insert the wheel flange into the drive splines, there is maybe a 1/16" of play at the drive flange pins rocking it gently forward and back. Seems like a lot. But I've never seen a spec on acceptable wear, and I've sure seen worse in pics.
So the question is:
1, Run it as is, maybe check it halfway through season.
2. Wheel flange available used, with much less wear. Will it play well with used drive splines? No idea.
3. Wheel flange available new, again, will that play well with used drive splines?
The wheel flange seems softer than the drive splines, which makes sense if Honda considered it a wear part? Drives are no longer available new, but plenty of used if I need one. Additionally not entirely happy with the Loctite 8012. I have some TS70 moly and that's what is going in this time.
RT
So the question is:
RT
