Hi - my 2009 ST1300A has developed an issue with the key switch.
When turning on to fire up the starting sequence , prime the fuel pump etc, occasionally none of the lights in the RH panel will turn on at all. Obv then the bike does not fire up with the started switch.
If I wiggle the key then you can hear some clicks etc, the lights will either all come up as they should and bike will fire up with the starter switch. Or the lights except the F1 light, and consequently no fuel pump prime, and no fire up with the starter switch.
Sometimes the bike will start up and run, but there are no lights on the main dash, no revs, no speedometer response and no headlights.....
So I know I have an electrical issue (!) but not too sure where to start!
Any suggestions as to how I can whittle down the possible problems so I don't have to spend £££'s right from the get go?
Many thanks
Many thanks
