Bike doesn't start and was in the garage for a couple of years now. Only fuel used since the owner has this bike was 95/e10. This fuel is not the best for older bikes I understand. So, I persuaded the owner to use only 98/E5 as that is the only available alternative over here in The Netherlands.Why do you have the carbs out? Was the bike running poor or perhaps the water hoses needed replacing? If there are no tears in the Diaphragms they might be OK.
Again, start at the business-end of the carbs: the jets hiding behind float bowls... that E10 crap is prone to leave debris and corrosion there...Bike doesn't start and was in the garage for a couple of years now.
Sorry to hijack the thread.Your diaphragm's are stretched out badly. If you could find inexpensive replacements, I'd replace them.
As it is now, I can possibly see a delay in throttle response in the midrange, or potentially not being able to obtain full throttle rpm's from being so stretched out, not allowing the slides to be fully raised. Under load, you should be able to hit the rev limiter at 8500 rpm's.
NRP motorcycle carburettor repair specialist
NRP specialise in carburettor diaphragms, air cut-off valves [or coaster enrichment valves] carburettor overhaul kits and spares for all Japanese carbs.www.nrp-carbs.co.uk
