I am interested in adding cruise control to my ST1300, 2005 non ABS. I have seen discussions from back in 2008. I would like to know what type of equipment I should investigate. Any assistance is welcomed.
I have a throttle lock now. It slowly backs off. I have tightened it with no real improvement. I will check out the Rostra. Thank You!Rostra cruise control kit are is the comon electronic one mostly used, pricey. There are a number of throttle lock options.
Thanks, I will look into finding a unit.Expensive but excellent quality, support and installation instructions - MCCruise -
Cruise Control for Honda ST1300 / ST1300A servo - Motorcycle Cruise Control
NOTE: – The optional low switch bracket (below handlebar) will not fit unless higher handlebars or bar risers are fitted. See the product brochure for more details. If your bike is fitted with (or you plan to fit) LED brake lights or a brake-light modulator, then a modification to the wiring...mccruise.com
How expensive it is depends a lot on the value of the AUD vs USD.
I have them on all 4 of my ST1100s and they work as well as any 'factory' cruise out there.
If you plan on keeping the ST1300 for a good while and mentally 'spread the cost' over the years it is well worth IMHO.Thanks, I will look into finding a unit.
Andrew, I fear that their engineering expertise and business model is in tapping into the ECU, brain, or whatever, of throttle-by-wire systems and direct the actuation of the physical throttle mechanisms using pre-existing components.New kid on the block with positive initial reviews that is less than half the price of McCruise. They don't currently have systems for any motorcycles controlled by throttle cables, so no ST1300 kit available. Send them a request. If there are enough requests for a system for the ST1300 maybe they will consider it.
Canadian pricing- Viridian Cruise
US pricing- Viridian Cruise
I appreciate all the input. The bike has olny 60K miles. I love my bike. I plan on keeping it. After a lot of highway riding the last two years, I was either going to install cruise or get a new bike with cruise. In the US, the ST is no longer ofered new.Another vote for McCruise. Best cruise I've ever had. Expensive, yes. You have to decide if its worth it or not. It is for me...I do long distance rides. I also got their speedo corrector, and now my speedometer is accurate.
Their system appears to work with electronic throttle bodies only.New kid on the block with positive initial reviews that is less than half the price of McCruise. They don't currently have systems for any motorcycles controlled by throttle cables, so no ST1300 kit available. Send them a request. If there are enough requests for a system for the ST1300 maybe they will consider it.
Yes, correct, as mentioned;Their system appears to work with electronic throttle bodies only.
I doubt it as well simply because it is so much easier and cheaper to develop a cruise control system for a throttle-by-wire set-up.I doubt a cable interface and all the myriad variations they'd need to source, test and maintain stocke are of interest to them. Too bad.
my badYes, correct, as mentioned;
