As you may have seen in my other threads, I'm the proud new owner of a 1998 ST1100. I'm in the process of learning about it, and doing all the basic maintenance. One thing I'll be doing is changing the coolant. Now, in my other bike, and 1983 V45 Sabre, I made the switch to Evan's waterless coolant. It's a bit of a chore because you have to get all the water out before filling with the new waterless coolant. Once you have, however, the benefits are no corrosion, a boiling point of 375 degrees, and freezing point of about 40 below, and no pressure build up in your system (no water again). I found out that you want their Powersport type as it's thinner than their regular fluid. So far the Sabre is doing well with it, but I think there are other issues that will need to be addressed. In any case, I'm thinking I'll switch it over when I put it away in the Fall. Has anyone else made the switch to Evan's? If so, is it working well for you? When I'm heading home after work in the Summer and baking on I-94 during rush hour stop and go traffic, I want to make sure my bike has every advantage to deal with the heat. I'm also thinking about an oil cooler, but I' haven't had a chance to look into that yet. Anyone else?
Thanks again for all your feedback on the other threads, I really appreciate it!
Bob.
Bob.
