It appears that a small amount of grease is oozing out from my clutch lever and dropping onto the left fairing pocket cover. I learned that this grease is caustic, and actually stained the cover. It's a dark gray / black looking grease, looks nothing like clutch fluid, and appears to be leaking out of the pivot bolt area. Though I'll have to get a good picture and study it to be sure. I cannot prove it is grease. But the clutch fluid level is perfect, and it looks like different fluid.
It has happened twice in the last two months. I wiped the grease the first time and filed away a mental note to take a look if I saw any further signs. Now two months later, it did it again. The only thing in common between the two incidents, was that the length of the ride was in the 3+ hour range. I normally make it out for 2 hours at a time. These two rides happen to be longer.
Has anyone experience with this grease leaking out? Any ideas why? And what to do about it, other than clean it up? As I said, the grease is caustic and attacked the plastic pocket cover. I'd like to fix it so it doesn't happen again.
Thanks for any ideas.
Joel
Joel
