Big_Jim59
I am going to attempt to do a brake fluid flush on my ABS ST1300. I am not sure it has ever been done. It all looks pretty straight forward except for step #3
It says in step #3 remove left caliper & tilt up NS Back 15 degrees. (use a wire to hold it) I get that. Then using the proporting valve bleeder, vacuum bleed and pump secondary master cylinder.
Question: Do I need to pump the secondary cylinder (the one on the left brake caliper) while I bleed the proporting valve bleeder or is this pump the rear brake?
I just want to make sure I have this correct. I live in fear of sucking air into the system.
Steps that I have:
1) Left Front Caliper- Top Nipple - Fill from Top Res
2) Right Front Caliper - Top Nipple - Fill from Top Res
3a) Remove left caliper & tilt up NS Back 15 degrees. (use a wire to hold it)
3b) Proporting Valve Bleeder -Vacuum bleed and pump sec master cylinder. - location right side above the head and behind the coil
4) Rear caliper - Center Bleeder - Fill Rear Res
5) Right Front Caliper - Nipple on back of caliper - Fill Rear Res
6) Left Front Caliper- Nipple on back of caliper - Fill Rear Res
7) Rear Caliper - Rear Bleeder - Fill Rear Res
Steps that I have:
