So, as I'm going for a test ride (read: picking up my new-to-me ST1300) tomorrow, I figured I'd put up a review of the com kit that I've chosen to run with...
Before getting into it particularly, the big manufacturers in the arena are Sena and Cardo - there's others, but those are the main. I went for a Cardo unit for a few reasons:
I have a Schuberth C3, and fitting was only really complicated by me being hamfisted. I had to remove the Packtalk mount from the clip to attach the 3M flat sticky pad (the C3 has a lip that's a little too big, and I'd have had to cut the wind protector on the bottom of the C3 if I'd used the clip mount).
Remove the helmet lining, use the supplied 3M sticky pads to position earphones & mic, then add duct/masking tape generously to hold the wires in place, then re-insert lining. Job jobbed...
Power up test & pairing...
When I powered up & paired with my phone (simple process, well described in the Cardo manual), I found that I couldn't play streaming music from my phone. A little investigation showed the Cardo Bluetooth profile didn't support A2DP, despite Cardo saying it worked. No problem, I'm a Software Developer, so my natural instinct was "firmware update is probably going to fix that..." A little googling, and I'd signed up to the Cardo website, downloaded their tools, and updated/configured the Cardo to work using their website.
If you're less technically capable, and have to go through this, don't panic. It's normal for devices to sit on shelves for a while and the software teams keep working... Google the site, register, and do what it says on the screen. If anyone here particularly struggles, feel free to PM me and/or talk to Cardo support.
With the unit upgraded & configuration tweaked, I've setup the single touch call function to call my wife, enabled full voice control and set a button to open the Android Assistant on my phone (which means I can set navigation destinations without having to stop & get my phone out etc). A quick test call, everything appears to be working. A quick play of music (from the Amazon Music app), works like a charm now.
Voice control seems to work OK, I can say "Hey Cordo!..." followed by things like "call the wife" or "next track" and it does what it's told. Or I can say "Hey Cordo...OK Google, navigate me home!" - to which, in this instance, Google replied "Unable to find a route, you're already home."
One thing to note: There's two Cardo apps on Android... I found that one works, one doesn't. Cardo Connect (the older app) worked fine, Cardo SmartSet just told me that my device was incompatible (even after firmware upgrade), so that's been deleted...
For tomorrow's test ride, I'm planning a ride through the Peak District using the Cardo for navigation. Afterwards, I'll try podcasts & music with navigation through the Cardo while I ride home. I'll come back & edit this post with findings, and probably a couple of pictures....
- Sena documentation is vague re waterproofing. Lots of online complaints of Sena units not working properly in the rain, and I live in North Wales, UK (where our annual rainfall is such that I don't look at the weather, I just assume it's "wet"). Cardo win's with it's IP67 certificate.
- Both companies have an online support presence, but reviews suggest Cardo is more helpful than Sena. I've never talked to either, so I'm basing this simply on online PR impression - but if I ever do need to talk to support, I want them to at least be vaguely good.
- I'll be mostly commuting, without any other riders around me, so I didn't need to worry about intercom with any particular brand (btw, "universal intercom" is largely a lie, unless you do it by Bluetooth... and supposedly the Cardo has a real life intercom range of 0.6miles... more than enough for me to talk to a pillion).
