If you put in fresh gas in it when you stored it, I doubt that it has not been sitting long enough for the gas to have gone bad. That does not mean that you didn't fill up with bad gas however.
If you can hear the fuel pump prime, the injector wires have not been chewed on by mice, at least not badly enough to cause inoperative injectors. This doesn't mean that they haven't chewed on something else however.
Start by checking to see if there are any fault codes stored. If there is, you need to take care of that first.
Before putting the new plugs in, crank the engine over for a few seconds with the throttle held wide open to blow any excess fuel out of the cylinders.
Spray some plastic safe contact cleaner in to your kill switch and flip it back and forth between on and off a dozen times just to make sure that there is good contact. Your fuel pump primes and you have spark so this should not be the issue however, it costs nothing to do and a bad contact at this switch has been known to cause all kinds of weird effects, so there is nothing to loose.
After putting in the new plugs crank it without touching the throttle, if it is working properly it takes care of itself.
Do you know that your battery is good? Even if it cranks, a marginal battery has enough power to crank the engine over but not enough reserve to supply sufficient voltage to the electronics and ignition- the starter motor sucks up everything that a marginal battery can deliver. It would not hurt to get some booster cables and hook it up to your car battery before trying to start it again just to eliminate the battery as a possibility.
On the off chance that your gas is bad, there have been several people who have had this exact situation due to the ethanol in the gas gumming up the valves and causing them to stick. They were able to get it to start by repeated attempts at various throttle openings until the valves finally freed up. Exactly what the procedure was I don't recall. I think that Bob (
@SupraSabre) went through this. Maybe he will chime in and let you know what he did to diagnose it and overcome it.
