Has anyone tried balancing beads for their tires? Going to be installing new tires (Dunlop road smart 3) soon and was thinking about trying some of the balancing beads. Hopefully someone has tried them and can offer their thoughts.
Thanks for letting me know about your experience with them. I've used them in a dodge dually 3500 with no issues just never in a bike. I think I'll give them a try in the bike.I have used Dynabeads for some years now, everything from ST1100's to my current NT1100, including a 1250RT and a few other Honda's!
I used the classic car beads, over here they sell at a better price than those for M/C's!
Soother ride, more even tyre wear and easy enough to swap over to next set of tyres with the correct tools, a small vacuum cleaner being one of those!
Two ounces in each tyre and no need for any balance weights!
Yes, I recommend them!
You can still do puncture repairs with wiggly worms, just do it with the puncture hole as near to 90 degrees from the bottom, use you rubber cement liberally and insert the repair as normal, then leave it for 5-10 minutes to allow the glue to set before inflating and cutting off excess worm!
This has worked for me, you still get a few beads sticking to the glue on the inside but the tyre remains balanced due to the dynamic nature of the beads.
HTH
I got some ordered yesterday. thanks for your response.I've used them. They work well.
Thank you for your experience. I ordered some yesterday. I'm going to give them a try.I have used Dynabeads for some years now, everything from ST1100's to my current NT1100, including a 1250RT and a few other Honda's!
HTH
Gonna give them a try. Beads should be here tomorrow. Thanks for the info.Has anyone tried balancing beads for their tires? Going to be installing new tires (Dunlop road smart 3) soon and was thinking about trying some of the balancing beads. Hopefully someone has tried them and can offer their thoughts.
I have ran them in my dually for years just never in a motorcycle. I sold my motorcycle tire balancer years ago when I quit working on bikes. I don't have a good local shop that I trust anymore. So I figured I would give them a try and was just asking if anyone else had used them.<<<<<<<<<<<<DON'T READ!!!>>>>>>>>>>>>>>>>
(A dissenting opinion that's just opinion without facts from someone who's opinion isn't going to change. I should have just deleted this but after taking time to write it...)
Ok, sorry, but I've been seeing these off and on for years and just don't get it.
I've never used "balancing" beads over the last 40 years of riding and don't see the need. I also don't understand how they work or why they would work.
My quick search for articles on them didn't come up with any Myth Busters type serious investigation but only "works for me" type testimonials heavy with "well I paid for it so it must be working" bias.
As I understand it, these beads just roll around and "naturally distribute" themselves. Sounds like unsubstantiated snake-oil magic. All the beads are going to be piled up in the bottom of your tire when stopped and need to redistribute each time you start up.
One of the selling sites says:
Not suitable for all vehicles: They may not work well on lighter vehicles with soft suspensions due to the beads not redistributing quickly enough.
Potential for initial vibrations: When first installed, you might experience temporary vibrations as the beads settle into their optimal positions.
Add that to this...
How they work: When the tire rotates, the beads move around inside, naturally distributing themselves to counteract imbalances in the tire and wheel assembly.
...and it seems they would always gather to the bottom when you stop, need to re-distribute when you start and have "temporary vibrations" for a bit with possibility that your "lighter vehicle with soft suspension" may not get it working well because "beads not redistributing quickly enough."
Lot of indication there from a company selling the beads so they can say "hey, we said it may not work for you."
I'm not trying to start a war of opinions here. If you can, point me to a scientific study or some worthy data to show me they work. I did toss a weight once during a race at Road America (Elkhart Lake, Wi) and suffered a distinct vibration down each straight, so I know balanced tires are important. That would have been a great time to toss in some beads and see if the vibration abated.
Has anyone done that?
1. Run a bike with balanced tire. Observed a smooth ride.
2. Removed the tire weights. Observed an unbalanced definitive vibration.
3. Put in balancing beads. Observed a return to smooth ride.
Without a report from a trusted source or doing it myself (will never happen) I'll just continue with aligning the tire's dot appropriately and adding a minimal weight when/if needed.
Actually, strike that, even with a report from a trusted source, I'll still do a static balance. I know that works and I don't need to buy beads or clean up beads. Can't see how any minor possible benefit in tire life or improved mileage or smoother ride would be worth the hassle.
Later,
Kent Larson in Minnesota
Smoother ride that what an unbalanced tire? More even tire wear is just an opinion, no scientific method applied here.I have used Dynabeads for some years now, everything from ST1100's to my current NT1100, including a 1250RT and a few other Honda's!
Smoother ride, more even tyre wear and easy enough to swap over to next set of tyres with the correct tools, a small vacuum cleaner being one of those!
HTH
Thanks, Larry. I'll definitely accept you as a trusted source. However...They work because the heaviest part of tire/wheel assembly is the center of rotation, so the lightest part of the assembly is farthest from the center, which is where the beads migrate.
In other words, it doesn't throw the weight around the center, it rotates around the center of weight.
They don't really start working until the wheel is rotating faster than the beads can fall and roll around the inside of the tire, so centrifugal force takes effect.
The one thing you're omitting is that the vehicle suspension must allow for some motion of the wheel.Also, distance from center has a much bigger influence on where the beads would go. If the inside of the tire is completely uniform, there would be a random distribution regardless of weight imbalance. If the inside of the tire has a pocket further away from the center than the rest of the tire, all the beads would migrate to the "bulge".
Thanks for the information. I'm going to give them a try. I got rid of all my balancing equipment years ago and don't have a quality dealership to trust locally. The beads I'm going to run I've ran before in other vehicles with no issues just never had them in a bike before.I have some experience with balance beads so I will repeat my experiences. I can say IMO that they DO work, most of the time. I have added beads to an otherwise unbalanced tire and notice a complete improvement right away. The issue I had was that, on occasion, a slight vibration would appear, briefly, then disappear. I assume the distribution of the beads got disrupted and then it redistributed and everything was good again. Sometimes this would happen a few times a ride and sometimes I wouldn't notice it for a day or so. It was never annoying and never lasted long. I wouldnt even say "dont run them"... they Do work. Just pointing out an observation. Because I bought equipment to balance wheels statically, I just do it that way and have no vibrations this way either and I avoid other small cons of beads, like the concerns with moisture, plug glue and the mess when swapping tires. Also, beads are pricey as opposed to the cost of a wheel weight or 2.
