Anyone know where I can find Key Blanks for a GIVI top box?
Alliston, Ontario
2009 Suzuki Vstrom
I have a GiVI top box on my 2003 ST1300.. I only got one key when I bought it.. Sooooooo I am trying to find some extra Key blanks to make some more keys- But the local locksmith doesn't have any blanks that are right.. Any ideas??.. Cheers Dave
I got extra blanks from my local Honda dealer who is a Givi dealer I then had a locksmith cut them for me. Good luck.
I had trouble finding blanks after losing my spare for my Givi topbox. After talking with Mr. Givi, I ended up getting a whole new lock assembly from them and changing the lock set. Rotsa ruck with the blank search.
Ask safedoctor (forum member) he's our local locksmith. IIRC he said a gas cap key to a vw works...
This table should help you out depending on which Givi model you have. If you want a genuine Givi blank and your box is an E52 or V46, their part number is Z661G.
--Mark
Found three different blanks for three different Givi Boxes. a E-35, E46, and the Honda ST1300 Topbox. I just went to a good Lock Smith/safe shop here in the Denver area. Took my extra key and boxes with me. The Big Box Stores will not have them in most cases.
i have a honda line box and my key blank doesnt look like the Z661G key blank it looks more like a Z154 3 digit key blsnk. did they change the keys at one point over the years??
If you have the newer Givi V46 Top Box, the key is a security key with a wiggly groove down the center of the key. You have to get a duplicate by key number from Givi.
I bought Givi blanks for my E 52 sometime ago, but I can't find anyone to cut them because the blank is made of steel and not brass. The three places I went said it would tear up their key cutting machine
That number is the key code, & you can get replacement keys by calling Givi. The code should be on the lock, as well. A friend ordered a couple replacements a while back.
I have the ST1300 top box and it seems to be the same key as my friends Givi (he has a rather small givi box though.) The blank is an iLco with X132 stamped on it. It may still be a different key than your Givi though.
i cut keys for my work all the time, and steel keys are a killer on the cutter, and at 50 to 100 for cutters i can see why they wont do it, but one thing u can do is if u put the cut key on top of the new ones and use a file to make a copy of the key, might take a little time but u will have copys then...
Unless you happen to file too much away and file the original key down too...:eek:4:
Geeez I can't wim..I was in Seattle on buisness and found a blank at a bike shop- Came home and while it looks the same as my key- The profile is totally different.. boy was I bummed...lol
Same with my E55. Givi lists only a lock re-key kit for either one or three locksets. Still means you only get one key. I'd like a spare, so guess I'll give them a call.....
So did Givi make the Honda line top box? I guess it's the Pan-Euro?
I have to Pan-Euro top box and have been looking for a spare also. I have the Givi E52 on my Honda 919 and the keys look similar.
FYI, I emailed Givi, and for the squiggly Security Locks, they don't offer spare Security keys. You have to replace the lock set (which won't likely match your key). So, to get two keys (and locks), you order the SL102..... SL103 for 3 keys. Description vague and does not categorically state 2 or 4 keys, so I've clarified all that with Givi (they responded to emails rather quickly, wow).
Edit - went shopping on ebay.... pictorial for the SL103 shows 6 keys....... and says not compatible with E55 Maxia.
