CYYJ
Michael
The throttle body of the ST 1300 sits on top of four rubber insulators. These insulators connect the throttle body to the cylinder head intake and they prevent heat from being transmitted from the engine casing to the throttle body.
There are two clamps on each insulator, one at the bottom and one at the top. Instead of publishing a torque specification for these clamps, Honda specifies that the gap between the two ends of each clamp needs to be 10 mm for the lower (cylinder head) clamps, and 7 mm for the upper (throttle body) clamps. It is difficult to get a ruler or a caliper down there to measure the gap, so, I created my own measuring tool by cutting up a plastic credit-card size hotel room key. You could use an old credit card for the same purpose.
The photos below show how to make and use the tool.
Be aware that when you install the clamps on the insulator, there are little holes around the perimeter of the clamp that fit over nibs on the insulator. The lower and upper clamps are different part numbers. If you mix the clamps up, you can sort them out easily enough: the lower clamps have two holes in the perimeter, and the upper clamps have four holes in the perimeter.
When reinstalling clamps, pay close attention to correct 'orientation' of the JIS (Japanese Industrial Specification) screw-hole on each clamp. You want to be able to reach the screw-hole with a screwdriver after the throttle body has been installed. This means the screw-hole has to face the correct direction. When you are installing the lower clamps - before you install the throttle body - you have easy access from above, but once the throttle body has been installed, you will only be able to access the screw-holes on the lower clamps (without removing the throttle body) if you correctly oriented the clamps when you installed them. The photo at the bottom shows the only path the screwdriver will be able to take to get access to the screw-holes.
Michael
Making the tool from a plastic hotel room key
Page 1-15 of the ST 1300 Service Manual, showing the distance specifications
Checking for the correct gap using the tool
Correct orientation of screw-hole on clamps
The point of the arrow shows the approach that the JIS screwdriver will follow to reach the screw-holes on the clamps.
Michael
