Never had a large tank fail, but my 60 gallon vertical air compressor tank... she was a-hissing when I came into the shop this morning. Closer inspection shows what looks to be rust through the weld of the drain fitting on the bottom.
I thought I would try to remove the approx 50mm plug in the bottom, which is tapped for a 1/2" npt to install a drain (I do have a drain installed and it automatically purges air from the bottom of the tank twice a day, 30 seconds each time). I have removed the fittings except for the actual plug and I'll be danged if I can get it out.
A 30mm socket fits the plug and when I used a breaker bar I thought I was going to break the bar. I was getting worried about messing up the flats so I got my air impact driver out and laid onto it for a solid 3 to 5 minutes and it ain't budging.
My suspicion is that the plug is fairly well rusted on the inside. I was hoping to remove the plug and (hopefully) get a hand inside where I might be able to clean up the rust a bit and lay down some JB Weld on the interior, hoping that it would seal enough to hold my 135 psi.
Wisdom of the list....
What are the chances I might get that plug out? Anyone ever remove one from an air tank?
Should I abandon my DIY fix and just break down and buy a new tank? ($500+)
Another thought would be to try to silver solder the pinhole from the outside. The leak appears to be a crack-like fracture right where the weld hits the tank, which is a fairly common place for these to fail. I'm not convinced it would hold from the outside and even if it did... how long it would last.
Fear: Inside of the tank is trashed and I just wasted a bunch of time and effort pulling a plug for nothing.
The tank is an Ingersol Rand vertical 60 gallon with a 5 hp 2-stage compressor. Model SS5L5 if you want to know. These were cheap compressors using oversea motors that were kind of known for catching on fire. I replaced my motor, but I'm glad I pay attention to my equipment. I heard it sounding "off" and investigated. I found burned wires and could smell the cooked insulation.
I replaced the motor and need the 18cfm at 90 psi of the pump. Both are operational and in good shape. Getting a new tank seems to be the reasonable choice, but the cheapskate in me doesn't want to spend the money. I've only had this tank about 12 to 15 years. Looks like new on the outside. But, the local compressor guy says that they aren't lined and do rust through. Some last 10 years, others last 30. Just depends on if the welds internally allow for a place for condensation to create a pool of water to sit there and rust.
Comments... opinions.... etc...
