air chuck for adding air to tires
kansas
Well i can't find any threads on air chucks just air gauges. Seems like most air chucks are a pain to get in and add air to your tires. Just picked up a 90 degree air chuck from napa $8, and works great. Will work better when i pick up a air gauge that adds air (the tool with the red hose) Thought this might help someone.
attachment.php
Oh Yeah!!!! thats much more better than what I'm using, will run out and get one too. $8 at NAPA, OK then, there juST down the street.
Thanks a bunch
attachment.php
I have one of those from snapon but it has a straight end I found on the rear tire I can go thru the brake rotor and the inside of the rim and ad air easy. I think that chuck would make it easier Thanks for sharing.
I never realized they made a chuck with a 90? head on it like that. I'm going to have to pick one up.
attachment.php
Stopped at NAPA today but the only 90 degree air chuck they had was $54!! Do you have the part #? Maybe there is more than one. Thanks. Russ.
Valve/gauge/chuck combos like that (mostly made by Milton) run about $50, but they'll be the last one you ever buy.
--Mark
It was $54 just for the chuck. (I'd have to call it Charles at that price!:D)
90d chuck I like , but cost over-rode and I use the cheap 1" one at home.
As to fitting another's air chuck, it doesn't matter as I carry a Check - a- spare.
I have a combination of what's already been mentioned. I use the Sears 360 degree adapter, with a short, one-inch 90-degree chuck. Works great on rear tires like the ST's (which have both a big disk on one side, a final drive pumpkin on the other and hardbags adding to the lack of workroom. I can literally feel my way to the air valve without seeing it. And works just as well on dirt tires, car tires, etc.
I use a CyclePump, or should I say "used to use a CyclePump", I could never get a consistent purchase with the spring loaded chuck, so now I use a Slime piece of kit that's designed for trucks. It has a screw-on chuck - that's very handy - on the end of a green spiral hose. However, it's a little too big to take on the road for my liking. I like the size and performance of the CyclePump and wondered if anyone has figured out a better chuck for the CyclePump? Most of the easily available chucks that I've tried on the CyclePump are 1/4 inch and don't seem to work very well. I like to have my own air & repair with me when I'm on a multi-day trip.
BTW I'm getting angled valve stems the next time I change my tires.
