So i scored a sweet pelican case today and I'm hoping to install it on my rear rack to use as a top case. I've been wanting one of these and it fits my laptop bag very nicely. I don't use the rear seat and can afford to encroach on it some but need to be able to get the rear seat off without using tools. so then, would you simply mount it with the four holes in the rear rack by drilling four holes in the pelican case or would you try raise it up by installing some other plate or something. I'm fine with bolting it down and do not plan to take it on/off regularly. It is pretty darn spacious, seems light enough and i've seen folks use them for this application successfully, just not on the ST1300. I looked at the turbocity rack and considered using it to mount the box, but didn't want to the extra expense and am not sure it would provide any additional benefit for the added weight/expense. If I lay it flat on the rear rack, it seems to contact the grab handles lightly, so I may have to construct some spacers or use some large washers or something.
any suggestions/ideas? I'm a little tentative about drilling the holes in the case and want to feel good about the placement before i do so.
