Hi I would like to add a GPS unit to my bike but don't want to just connect to the battery is there any other way I can wire it. I'm not very good when it comes to 12v wiring
Thanks for the link. I will have a look at thisIf it is only a GPS the below article will show you what do. If your electrical requirements increase in the future consider an auxiliary fuse box.
Article [13] - ST1300 - Switched Power Tap | ST1300 Articles
There is a location on the ST1300 that is great for a switched power tap in case you just have a couple things to power or you need a switched tap for your fuse box. Below are the steps to get to the power location: Remove left saddlebag and left side panel to expose the OEM fusebox...www.st-owners.com
OuchIf you are not good with 12v wiring, pay someone who is. Wiring is not something to be messed with if you don’t know what you are doing.
Ouch
........pay someone ........
I don’t like electrical failure points attached to my motorcycles.
I purchased a couple battery cells for my cell phone, and put it in my pocket, and run my GPS off them.
Each one will hole like three complete charges on my phone as well.
I ran 1000 miles this way and only used a couple bars on the battery pack.
Then you can charge them in your hotel etc.
I have a zumo 346. And An ST1300 2011Not a big deal.. 12v is easy... you've got a positive and a negative.
What GPS? The Zumo XT for instance comes with a small box that converts the 12v to 5v output for that GPS. Most if not all phones you plug into a USB assumes a 5v output.
The Zumo XT2 is actually 12v so doesn't need the converter.
The tapped power source in the post #4 is good, I used that on my ST for several years. Read the entire thread as there's a slight difference based on which year bike you have.
Some of those jump starters for cars and bikes have a USB port and can be used for this purpose. If you use it to power your GPS, don't plan on using it to jump your bike....it might be depleted when you need it for that.I don’t like electrical failure points attached to my motorcycles.
Hi Crozzy, I had the Eastern Beaver PC-8R Fuse panel on my ST1300. If you plan to keep your ST then it is a very worthwhile addition and will handle many other 12V accessories that come along. I had mine mounted under the rear seat and it performed reliably for many years. You can have 'switched' power that comes on with the ignition, or direct power, all though the fuse ratings of your choice. Check out the EB website.Hi I would like to add a GPS unit to my bike but don't want to just connect to the battery is there any other way I can wire it. I'm not very good when it comes to 12v wiring
And I'd hate to cut or tap into OEM wiring...I don’t like electrical failure points attached to my motorcycles.
