My 2007 ST1300ABS apparently is having ABS issues. The light comes on and will not go off.
Any suggestions?
Any suggestions?
Flushed the brake fluid?. . . when’s the last time you flushed the brake fluid?
Yes, call me, I have a couple things you will want to test/check before some stealership tries to convince you that you need to replace the very expensive ABS unit (which it never is)My 2007 ST1300ABS apparently is having ABS issues. The light comes on and will not go off.
Any suggestions?
I think it would help to add what older fluid can do to mess up the ABS sensor response. I certainly don't know!Pics of the front wheel please. Showing the sensor wheel, when’s the last time you flushed the brake fluid? Any maintenance performed recently?
