3D Printed Mirror filler pieces for ST1100
jdmccright
Vendor
La Plata, MD
2000 ST1100
To all,
My next items I've been able to finish and finally offer are the inner pieces that fill in between the mirror and fairing. These are 3D printed in black ABS. Haven't added any special lettering or other graphics but I can if desired, like "HONDA" or "ST1100" or whatever custom.
Cost is $10 (USD) per pair. Shipping is $6 in the USA, and $15 international for up to 3 pairs.
I don't own an 1100 so just curious: What usually goes there?
A blank plug fits in there that uses a metal clip to hold it. Very common to bend that clip trying to reinstall it, making the plug loose or even fall out. The one I designed doesn't need that clip.
These replace the featureless snap-in covers that were stock. They cover an access hole. Allows access to the adjustment screws on either rear carb without having to remove the plastic side covers. You can also remove the two aft spark plugs using these two openings.
These are diferent than what Nexus was asking about. Sorry if I added to the confusion.
I do print replacements for both parts. The filler panels are not painted. The carb access plugs are only accent painted. Those are shown here:
