I have recently acquired a 2008 ST1300 ABS which was sold new here in NZ.
This bike has sat in a shed for 2 years. the previous owner stated that it was fine when parked but he fitted a new battery recently only to find a problem.
The bike starts and drives fine but....
The headlight, Windscreen, Digital meter, neutral/oil/battery etc lights, speedo, tacho, stop/tail light/ horn are all not working.
The clock is working and the dash does light up briefly when the key is turned.
Indicators work fine.
I have seen some discussions about this issue but they all seem to end up down rabbit holes of added accessories and ripoff dealers.
The only modification is some led front indicators
I have stripped all the plastics off to troubleshoot.
The battery is hooked up to a jump starter so that's not the issue.
60A fusible link is fine
30A main fuse is fine
All fuses in both fuse boxes are fine
There is no power to following fuses 10A ABS MAIN, 10A POSITION METER LIGHT TAIL, 10A H/LIGHT
All other fuses have power to them.
I have pulled the white 24pin plug apart. the grease was pretty dirty so I have cleaned it up. All wires look fine.
The yellow 14 pin earth bus looks fine,
The main earth under the tank looks fine.
Any ideas as to what is going on or where to look next would be greatly appreciated.
