sendin
Denny from Sebastopol
I over filled and wanted to see if there is another way to remove oil other than using the oil drain plug. I think I will end up dumping more oil than I want to by using the drain plug. I tried using a small diameter soft silicone tube down the fill hole to just siphon some out, but that didn’t work. It’s probably only a cup or a cup and a half overfilled. Thanks in advance for any solutions or suggestions. Denny
