The bikersdream looks like a great item, but Amazon says it cannot be delivered to my address (USA) using your link. And logging on to Amazon and doing a search for that brand and specific item shows up as out of stock and unavailable.I have however upgraded it with the very well designed Bikersdream Schrader Adapter, which enables attachment without any pressure loss...
Ditto. Anybody know of an equivalent adapter available on this side of the pond? TIAThe bikersdream looks like a great item, but Amazon says it cannot be delivered to my address (USA) using your link. And logging on to Amazon and doing a search for that brand and specific item shows up as out of stock and unavailable.
Yikes! $20 USD plus $62 USD shipping, unless I misunderstood the site…
I got the same message in that link.The bikersdream looks like a great item, but Amazon says it cannot be delivered to my address (USA) using your link. And logging on to Amazon and doing a search for that brand and specific item shows up as out of stock and unavailable.
yes it's just for an emergency when the tire I'm repairing doesn't have it's own 45/80/90 degrees valve stem, like my wife's XMax scooter for example, that is nearly impossible to get to the straight valve stem on the tiny scooter wheels.Be careful about using that 90 degree valve stem extender. In fact do NOT put it on a rubber valve stem other than for temporary putting air in a tire and then remove it before you drive.
interesting video. thanks for postingSomewhere on YouTube there is a video that someone made that compared quite a few of these little rechargeable self contained compressors. There was a huge difference between different models as far as battery life and how fast they could fill a tire. Some were almost unusable and others worked fairly well.
See video
I have an Airmoto like the one in the video. I use it for topping off my motorcycle & bicycle tires. For this purpose I prefer it over my 120v 125 psi garage compressor and the 12v portables in each bike. It might not inflate a car tire quickly but I don't use it for that. It adds up to 15 lbs in what I guess to be about 1 or 2 minutes.interesting video. thanks for posting
I have the Airmoto as well- to me, very useful for a few PSI to bring the tire up prior to a ride- not sure if it would work well if the tire was completely deflated. I usually also carry an electric one (runs off the SAE battery connector) in the kit I have as well as 3 different tire plug kits. The Airmoto is much better than using a manual bicycle pump (as I’ve done in the past) for that few PSI.I have an Airmoto like the one in the video. I use it for topping off my motorcycle & bicycle tires. For this purpose I prefer it over my 120v 125 psi garage compressor and the 12v portables in each bike. It might not inflate a car tire quickly but I don't use it for that. It adds up to 15 lbs in what I guess to be about 1 or 2 minutes.
