Nope, but I doubt it would do much good for your ribs ...
You never watch "A Knights Tale:???Nope, but I doubt it would do much good for your ribs ...![]()
Nope, but I figure when you hit the ground the metal would bend in and whack your ribs!You never watch "A Knights Tale:???![]()
How do you do that?Just need to check the CO2 cartridge every riding season.
My guess is you weigh them on a kitchen scale.How do you do that?
Hit Air sells a small tether with a clip on it so that when you park, you can clip the part that would plug into your vest so it’s not dangling on the bike.From what I could find, the Helite 'Electronic' vest does not deploy at under 12 mph without the fork sensors.
And it does not appear that you can get the sensors in the USA at this point.
That 12 mph thing really bothers me because low speed is often where you end up tipping over and crashing - and it can cause some physical damage!
I pulled into a gas station at night and did not see this big pothole in the concrete.
When I went over, my ribs hit the edge of the curb and it was not pretty - and I was doing way less than 12 mph.
Having ridden with the tether for a whole day with several mount/dismounts, it is just not that big of a deal.
For getting on, you just need a little hook somewhere on the tank in front of you to hang the end of the tether.
If you forget to untether, you get reminded pretty quickly.
Being in the computer business for 50 years, I'd much rather trust the tether than some programmer's ability to 'predict' when I am crashing.
With the tether properly installed, physics usually dictates that you will be separated from the bike.
Not 100% but the odds are as good as depending on software - trust me on that one!
I know the pro racers have the electronics but understand they ride in a different world than street riders.![]()
Seems to me, the tether satisfies this requirement, rather than tech/electronic stuff.Rationale is to keep it simple for me.
I do remember reading that somewhere. CO2 adds weight ?My guess is you weigh them on a kitchen scale.
In order to know whether your canister is still good; make sure you weigh it every year. The weight should not deviate more then 3 gr from its original weight which is 182 gram for the 60cc orI do remember reading that somewhere. CO2 adds weight ?
I ran the tether around the frame and the triangle brace on the right side (hard to see in the picture).Where did you connect yours on the ST? I’m interested as if yours is in a good spot, I may want to change the location of mine away from the handlebars.
As Uncle Phil and Tom have mentioned.How do you do that?
It amazes me that you ever make any decision ….And a confused prospect will rarely buy...
I still can't reconcile (or haven't reconciled) this entire conundrum.
External vest?
Susceptible to being shredded sliding on the asphalt, and rupturing after expansion.
Then again, if it inflates prior to impact, it's done its job, and passes off the slide damage to the rest of the gear you should be wearing underneath it.
Internal vest?
Now I need to consider buying new jacket one size larger, to allow room for inflation.
This would be like buying new britches, bigger in the waist if you switch from an outside- the- waistband holster to inside- the- waistband.
All these questions.
Just thinking out loud; all this is discussed elsewhere.
