diferg
Dan & Ingrid
No I believe the GW could power a small city!
I was asking about the Suzuki GSX-S1000GT.
that's the same concept I used with my PVC pipe when I toured on my FZR, before I bought my ST. Just curious, does that lever the bike into the air with the handle like a jack, or do you have to lift the bike by the footpeg and place the support under the swingarm?A centerstand is nice but at home you can use a pit stand, and on the road you can use a portable device that costs under $30 and packs down very small, such as these: https://www.amazon.com/GUAIMI-Motor...torcycle+paddock+stand&qid=1632583959&sr=8-30
Looks to me like you can lever it up.that's the same concept I used with my PVC pipe when I toured on my FZR, before I bought my ST. Just curious, does that lever the bike into the air with the handle like a jack, or do you have to lift the bike by the footpeg and place the support under the swingarm?
Well, it's 5 gallons, not 4.6. But I'm not sure it's considered a "long-distance motorcycle," i.e. a competitive LD/Ironbutt ride, out of the box. Most people who do that sort of activity use auxiliary fuel systems anyway, even those with massive OEM tanks such as on the ST1100/ST1300. I mostly get along just fine with the 4.8 gallon tank on my GSX1250, even living in Nevada where there are sometimes 160 mile stretches between fuel availability. And I usually need to get off the bike every 100 miles or so anyway, for a break.4.6 gallons of fuel is a joke for a long distance motorcycle.
for 24 years I've consistently gotten 50mpg with my 1100 if I kept my speed in the 70-75mph range, and worst case is 45mpg if I run in the 80-ish range. I'd consider that fairly good mileage, and similar to other liter-bikes I've owned.It is a good thing the ST has a big tank because it really doesn't get that good of mileage, especially if you start to push it.
It's interesting how much variation there can be in the same model of motorcycle. I had three ST1100's. My first one, a 96 standard, consistently got well over 45 mpg. The other two, a 92 standard and a 98 ABS, rarely got over 43 - all of them being driven in the same manner. Go figure.for 24 years I've consistently gotten 50mpg with my 1100 if I kept my speed in the 70-75mph range, and worst case is 45mpg if I run in the 80-ish range. I'd consider that fairly good mileage, and similar to other liter-bikes I've owned.
Easy peasy is relative. By your metric, during a rally you'd be lubing your chain twice per day and cleaning it every two days. Shaft drives last forever with very infrequent maintenance.If it has as big an alternator as my GSX1250FA-ST, it'll be plenty, especially considering that it comes with all LED lights. As far as fuel capacity is concerned, 5 gallons will get you 200+ miles of range unless you're really misbehaving, which is enough for pretty much any dry stretch in the USA.
As far as a centerstand and a chain is concerned, the chain IMO is preferable to shaft drive - it saves a lot of weight, you can change gear ratios if you want, and modern chains easily go 30,000 miles or more without replacement. I just lube mine every 600 miles or so with a good lube that doesn't attract dirt (Amsoil chain lube), and clean it with a brush every few thousand miles - easy peasy. I've never had to adjust a chain on any of my modern chain-drive bikes.
Yet another reason to avoid traveling with guys that have disparate bikes and riding styles.As for fuel range, the last couple of bikes I've had (CBR and VFR) would go 200 miles. You're taking a bio break every couple of hours anyway, top off the tank, no biggie at all. LOL, I'm usually leading the group and it's the ST guys who think they can skip that and go extra, then they want fuel and hold the rest of us up..... don't worry, you'll adapt. All is kool.
I guess your definition of sport tourer is not the same as mine...... do FJR's count (240 mile range) or C14's? How far will your GL1800 go, 250? It's all mine would do.Yet another reason to avoid traveling with guys that have disparate bikes and riding styles.
If you are on day rides with buddies on nakeds or sport bikes then tank range doesn’t matter but a new sport touring offering naturally will be compared against contemporary and legacy sport touring bikes.
You mentioned leading the ride and CBR in the same context. You consider the CBR not to be a sport bike?I guess your definition of sport tourer is not the same as mine...... do FJR's count (240 mile range) or C14's? How far will your GL1800 go, 250? It's all mine would do.
I don't ride with naked or sport bikes........
Well, we could argue all day about the relative merits, I guess. I prefer the weight savings, flexibility, and ease of repair of the chain drive. A lot of BMW owners have suffered final drive failures on their shaft machines, so they don't all actually last forever. And I note that even though most Iron Butt Rally riders prefer shafties, the 2021 IBR was won on a Hayabusa, a chain drive bike. Thirty years ago there was a definite advantage to shaft drive. Nowadays, not so much, and IMO, chain drives have some definite advantages. YMMV.Easy peasy is relative. By your metric, during a rally you'd be lubing your chain twice per day and cleaning it every two days. Shaft drives last forever with very infrequent maintenance.
Exactly as I said in post #69You all may find this hard to believe, but there are a ton of different bikes out there, all with folks who think their's is the only choice possible. If you are happy with your choice, you don't need any supporting comments from others. Just go ride..
