New G6 H4 LED bulb with SHIELD is now availible - no glare no scatter.
We did it. It works. You no longer have to do it yourself. I have put 17,000 miles on the prototype and these are better.
------------------ update ------------------2018---------------------------
I also noticed that some of these sites are running out of the H4 version of the G6 bulb. Gee... I wonder why.......)
I am getting questions about not being able to find the Evitek G6 H4 bulb. I too needed to get another set and could not find them either. So I did some looking around.
There is a lot more stuff out there now and confusing!
In 2017 they came out with the T8 bulb with a fan and the S1 bulb without a fan.
In 2018 they came out with the F2 bulb with a fan.
G6 is 22 watts, tall beam, shortest reach.
S1 is 22 watts, mid beam
T8 is 25 watts, mid beam
F2 is 30 watts, thin beam, most focus, more light to the horizon. This one is most like the original Halogen bulb....
The F2 is about 50% brighter and is narrower focused than the G6.
If you double the power you will only see 50% further, If you cut the beam angle in half you will see twice as far...
Is it worth throwing away the G6 and getting the F2? I would say NO, since the improvement is really only slightly noticeable.
They all create DOT compliant beam patterns. One is not better than the other, just slightly different. It depends on your riding style needs...
If you just want the best available in 2018, just look for the F2 led. It looks like this and will be sold under different labels.
A new DOT spec needs to be written and the F2 LED should be the mold around which it should be made.
The tolerances should allow that the T8 and S1 should be acceptable. I hope we do not have to wait 21 years like we did for the H4 to become the 9003....
It should be available soon on amazon from Evitek.
You can get it now from JDM for a price....
https://www.amazon.com/JDM-ASTAR-Ge...sr=8-19-spons&keywords=headlight+h4+led&psc=1
or
https://www.amazon.com/Safego-Headl...111185&sr=8-2-fkmr1&keywords=evitek+led+h4+f2
or you can still call Cindy at Evitek and order direct and wait for the package....
Tech differences
The G6 had a heatspreader sandwiched between two circuitboards. The F2 has one circuit board between two heatspreders. The plus is better focus, the minus is higher spot temperature.
So it will take some time to prove long term reliability. I just swapped out my G6's and put in a set of F2's. I will keep the G6's in my top box just in case....
And there are others that work as well, Read below for the story or skip to the end for updates
-------------------------------------------------------- update ----------------------------------
I helped develop this bulb. It creates a nice flat cut off that prevents glare to on coming drivers and allows the driver/rider to see further down the road. This is the best H4 led bulb on the market. No glare. No scatter. Enjoy
Thank you to all on this forum who helped with this project. The magic is in the Shield.
Below is the original unshielded G3 bulb on the left verses the new Shielded G6 bulb on the right in my ST1300.
or
Tech differences
