Update see #84 !!! New G6 shielded bulb on Amazon.
you no longer need to modify anything
URL: https://www.amazon.com/Headlight-Ev...sr=8-3&keywords=EVITEK h4&tag=viglink20849-20
I replaced my ST1300 left headlight bulb twice so I looked into using Led H4 bulbs. I have tested a bunch of H4 led replacements for the ST. This is the one that in my opinion works best --- if you modify the G3...
Search EBay for
LED Bulb H4 HB2 9003 2015 CREE 40W
Look for the one that looks like the one pictured here with 2 (offset) Leds mounted on each side. The Leds point to the sides not up. The full photo has foil tape that I used as a prototype.
From my evaluations: Those H4 Leds with large emitters do not focus well. They put light everywhere and are fine if used off-road. Those with small emitters focus better and can be tailored to reduce glare.
Those H4 Leds that point UP/DOWN work only in round lens. Do not use in rectangular lenses or in the ST. The ST fairing blocks part of the top of the lens which makes this type not the most efficient choice for the ST1300.
Those H4 Leds that point to the sides will work in both round and rectangular lenses. They are the better choice for the ST. However the low beam emitter must be shielded to prevent the light from getting into the bottom of the lens.
If you look closely at the Halogen H4 bulb you will notice a metal plate under the low beam filament. If you look at my LED light pattern (Left) photo without a lower shield you will see upper wings of light that create glare for oncoming traffic. Putting a shield under the low beam LED blocks the light from getting into the bottom of the reflector (H4) and creates a sharper cut off (Right) photo.
But I also noticed that there was a lot of close in light that created glare for the ST rider. This was coming from the chrome part of the fairing juST above and in front of the lens but behind the clear plaSTic lens cover. This is why I also put a shield over the top of the light. The shield also redirects the "wasted" light back into the reflector and back where you want it.
The shield was made from thin aluminum flashing found in the Home Depot roofing department. But you could simply cut up an empty beer/ soda can with a pair of scissors. The screw is a T6 Torx. To be safe I coated the circuit board with just one coat of clear finger nail polish. Do not get any finger nail polish on the led lens. Let it dry then mount the shield. The mounting hole is offset and different for each side. The bottom shield is at 90 degrees and the top shield is at 45 degrees.
I had to trim out the middle of the rubber boot in order to mount the light. First install just the ring without the bulb. Then install the trimmed rubber boot. Then install the light through the rubber boot into the ring. Turn to lock in place. The fan will be outside of the rubber boot. I tucked the connector and the power module into fairing sides. It is easier to get to the bulb on the ST by reaching under the front of the fairing.
Now these lights claim to be 40 watts because they use four 10 watt Leds. If you measure the power you will only measure 20 watts but 5 watts is used by the fan so you are only getting 15 watts of light low beam and 30 watts on high beam. The low beam uses the front two LEDs and the high beam uses all four LEDs. At this power level the fan is necessary for long life. Avoid the ones without a fan. They will last you more than a million miles or five ST1300’s
These Leds put out a lot more light than halogen lights. However the hot spot of the halogen and the center spot of the led measure about the same lux at 10 feet. But the Led has a much wider bright beam. So all that extra lumens lights up the sides of the road better. I have 10 watt Led fog lights mounted on the forks. They made a big difference when I had halogen headlights. Now that I have converted my headlights to Leds, I barely notice the improvement when I turn on the Led fog lights. In several thousand miles of night driving with these shielded LEDs no one has flashed back at me.
Oh. I also replaced my marker lights with this led from superbrightleds.com -WLED-xHP15-TAC. But before I installed them, I coated it with several coats of clear fingernail polish to help glue the small circuit boards together and protect it from being shaken apart. They match the color of the new Led headlights.
I hope this helps. enjoy.
Read post #12 and #14 for my Final updates....
or you can skip to the thread on the G6 bulb by EVITEK
https://www.st-owners.com/forums/sh...-now-availible-no-glare-no-scatter&highlight=
Search EBay for
