No article to lead me by the nose on replacing the front pads. The service manual says push the pistons in. It doesnt say how. Also what about cleaning the pistons BEFORE I try to push them in... What technique to you all use?????? Thanks Dan
Dan, I pull the old pads and using a toothbrush and brake fluid I clean the piSTons. Re-inStall the pads and using a blunt inSTrument..I carefully use a screwdriver..push the piSTons in via the pads. You can push the caliper towards the disc and push the piSTons in too. If you have ever topped off the maSTer cylinder make sure you suck out some fluid before you push the piSTons in..carpevita said:No article to lead me by the nose on replacing the front pads. The service manual says push the pistons in. It doesnt say how. Also what about cleaning the pistons BEFORE I try to push them in... What technique to you all use?????? Thanks Dan
dond said:Dan, I pull the old pads and using a toothbrush and brake fluid I clean the piSTons. Re-inStall the pads and using a blunt inSTrument..I carefully use a screwdriver..push the piSTons in via the pads. You can push the caliper towards the disc and push the piSTons in too. If you have ever topped off the maSTer cylinder make sure you suck out some fluid before you push the piSTons in..
hth
ymmv
yadayada
Rob Hephner said:Spray some cleaner before you pull the pads (place a towel in the way of the overspay), then use the pad in place to push the pistons all the way in.
Then remove the pad and replace.
Key word= Icarpevita said:Thanks for the info . So there is no need to take off the two bolts that hold the caliper to the wheel..?
Also, How do you avoid the brake cleaner from getting on the tire if you dont remove the wheel...
