Corbin Solo Seat - '09 ST1300PA
Florida
Has anyone come up with a solution to mounting a Corbin Solo seat onto the ST1300PA? I want to keep the rear cowling and solo seat look, so I had hoped I wouldn't need to swap the subframe or do any metal cutting on the bike.
Specifically, the Corbin seat came with a cross bar spanning the rear for a latch style system, while the ST1300PA stock seat has a flat bar with a hole drilled out to pin your mounting bolt through.
Obviously these two designs are incompatible as they are currently configured. Does someone make the ST1300PA seat bracket, or is there another solution to getting this new seat mounted?
I went and looked at my Corbin, on a shelf. The crossbar can be removed and you could fab up a straight crossbar to mount the police seat holder to it. Drill two holes, bolt through. If you think it through you maybe able to make more adjustable.
