ST1100 clutch master cylinder is 14.00mm id according to the service manual (section 1-11). VFR800Fi 98-01 and ST1300 is the same, VFR800 VTEC 02-13 uses 12.7mm.
For a given slave cylinder diameter, a smaller MC will decrease effort and slave piston movement for a given lever movement.
Correct - but to continue the point that I believe Terry was making, it is important to bear in mind that it is not a matter what size of
master cylinder you use, the
volume of hydraulic fluid required to operate the clutch is determined by the diameter and required stroke of the
slave cylinder.
The fluid
pressure required from the
master cylinder is determined by the stiffness of the clutch basket springs and the
diameter of the slave cylinder. The
volume of oil required from the
master is determined by the stroke and diameter of the
slave.
The volume of oil required is:
slave stroke x (3.14159 x (slave diameter)**2) / 4
For non-math types, the "
**2" means "squared". So, you multiply the (diameter x diameter) - i.e. multiply the diameter by itself, and then multiply by
pi (that is the "
3.14159" number) and then divide that result by
4 and
THEN multiply by the
stroke of the slave.
NOTE: all of the dimensions must be in millimeters (or inches) and then the volume will come out in cubic millimeters (or cubic inches).
From there, you go back to the
master cylinder volume and stroke and make sure that the volume numbers match.
The trick in switching to a smaller master cylinder will be to ensure that it can still provide sufficient fluid to move the slave enough to actuate the clutch properly.
For a given hand force on the clutch lever, you will certainly build more
pressure with a smaller
master cylinder, but if it doesn’t push enough fluid to operate the
slave with sufficient stroke to disengage the clutch, you will experience hard shifting and the bike will “creep” at idle, unless it is in neutral. Also, finding neutral will be very difficult if the clutch is not fully disengaged.
Essentially, the master
and slave cylinders of any clutch system (or calipers for a brake system) are matched by the design engineers and so changing either one of them
may result in a system that simply doesn’t work properly.
Pete
