Hi All,
The clutch on my '95 ST1100 outfit works perfectly on start-up. However, the clutch does not engage if I use the clutch lever when the engine is warm. Put simply; all is normal until I snick the bike into 1st gear with a warm engine. Nothing happens when I release the clutch to move off! The clutch remains disengaged with the clutch lever fully out.
This problem appeared suddenly, out of the blue, two days ago. Everything else on the bike is operating normally. I bled and changed the hydraulic fluid for clutch operation three weeks ago. The clutch operated faultlessly until two days ago.
In a way, I'm relieved that it is a clutch problem only. I thought I was dealing with a broken drive shaft when it first happened.
Any advice or comment will be greatly appreciated. Yep, I have already ordered a workshop manual. Nonetheless, advice coming from the lived experience of a problem is often more valuable. Safe riding, all!
