Excellent condition, been thoroughly checked out by @Igofar 29 months ago. Two new Michelin Road 6 tires (less than 100 miles) and all new brake pads just installed. Includes shop manual and assorted filters/parts. Always garaged, I'm third owner (second one didn't ride it much). Originally bought in Seattle. I hate to sell but finding my time spent on Adventure bikes these days. Reach out if any questions.
Rob
503-724-1041
Maintenance history:
20,400, Bought bike, Memorial Weekend 2020
20,400, June 2, oil change
20,400, Rear Final Drive Oil replaced
20,400, June 12, New front and rear tire
20,400, June 20, Rear drive oil change
20,400, June 21, Coolant change
20,400, SMC Replacement
20,400, Brake Bleed
20,500, New Air filter
21,000, Pre load adjuster service
21,500, throttle lubrication
21,500, new spark plugs
21,500, Heated grips installed
21,700, New rear tire after flat on last tire
21,700, oil change
22,000, LED headlight upgrade. Sept 1, 2021
Larry Epic 24,100, Dec 1-2, 2021:
Throttle body timing/synch
Coolant flush, radiator clean. Fix coolant leaks
New thermostat
Flush brake fluid
Cleaned front suspension seals/fluid
Balance front suspension/axle
Cleaned front brake pads
Clutch fluid flush
Replace Pre-load fluid, adjusted rear suspension
Oil change
25,500, Rear Final Drive oil change
27,150 Oil change
29,466, 2/10/24:
Oil/Filter change
New brake pads and spring clips all around
Brake bleed
New tires front and back, Michelin Road 6
New O-rings for rear drive, Molly for spline
New air stem front wheel
Rob
503-724-1041
20,400, Brake Bleed
21,700, oil change
New thermostat
Flush brake fluid
Clutch fluid flush
Oil change
27,150 Oil change
29,466, 2/10/24:
Oil/Filter change
Brake bleed
