This is my first post here. I've owned my 2001 ST1100 for three years and it's been awesome until mid summer this year, when one day I went to go for a ride and the battery was deader than a door nail. 100% flat. I charged it up rode it and the bike was fine for a couple of week, but then one day same thing. At this point I ordered a new battery and also started looking for shorts and also checked to fuse like to see if I needed the red wire bypass. Everything is just like new. No melting, discoloration. Contacts shiny and snug. I put the new battery in, bike ran fine for a couple more weeks, and then, yep... same thing again, completely flat battery. I charged up thr battery again aand at that point when I started the bike, I noticed that the output voltage was way high, like 18+ volts. (I have an SAE charge port with a voltage readout). It usually reads 12.7ish when bike hase been sitting a while. When the bike is running, it tops out at 14.2 to 14.4. BUT intermittently it will read very high, as I stated earlier, and I made the observation that when it's reading high and then shut off the bike, the next morning the battery is totally discharged. If it's reading 14.2 aand I shut off the bike, the battery is fine.
Questions:
1) Is it possible (intermittently) the rectifier/regulator has a short?
2) I assume, if this is my problem, the recifier is integrated in the alternator and I need a new alternator. Is this assumtion correct?
3) Is there a tutorial/instructions someone can point me to on the process of changing the alternator on the ST1100?
Many Thanks in advance! Neil
Questions:
